Beam-Column Node verification
5 REPLIES 5
stroxy
1304 Views, 5 Replies
When verifying RC beam column joint for seismic analysis EC8. I have a scenario where I have both a lower and upper column, but in the automatic generation of the node only the lower column appears with all relevant combinations, as well as all the beams framing into the joint with envelope/combinations.
The upper column is not automatically added. I notice I can manually select the upper column, but the combinations cannot be automatically assigned (correct?) ... Now with hundreds of combinations to choose from, how does one "manually" create/modify the combinations in the node?
5 REPLIES 5
stroxy
in reply to: stroxy
Realized the issue was due to having plastic moments activated in the column seismic analysis.
Question is how does one work around top storey columns (EC8) where node verification is not required but plastic moments need to be taken into consideration for shear verification.  Does one design the multi-storey top-floor column first without plastic moments to be able to verify the node at the column base and then check the design to see if it passes with plastic moments?  Or is there a simpler workaround?
Artur.Kosakowski
in reply to: stroxy
Stroxy,
You should have all columns and beams (that meet in the node you want to design) calculated (with generated reinforcement) before attempting to design the node itself. In such case the plastic moment should not be any obstacle.
Artur Kosakowski
genieyas
in reply to: stroxy
Hello Stroxy
i have the same issue, with the top story, how to indicate to robobat not to take node verification for the colomns of top storry because it gives me a very big colomn
Thinks for your help
genieyas
in reply to: stroxy
hello
you see in yoyr question "the automatic generation of the node" : how to make this automatic or manuel, please helpe me bacause i want to disable this chek for the colomn of the top story
Sincerly
genieyas
in reply to: Artur.Kosakowski
Hello Mr Artur,
It is possible to disable node verification for the top story. please helpe me i will get crazy to understand this issue.
Sincerly
