Discussion Groups
Robot Structural Analysis
Active Contributor
jamalsid
Accepted Solution
Baseplate with eccentric column and L shaped baseplates
437 Views, 3 Replies
03-01-2013 04:08 AM
Hello
Is it possible to use Robot's connection design module to design steel column baseplates where the columns are eccentric to the plate centre?
I also have a scenario with an L-shaped base plate and can't see a way to design this in robot eithre?
I have attached a drawing showing the base plate layouts I would like to verify in Robot.
Please use plain text.
Product Support
Artur.Kosakowski
Re: Baseplate with eccentric column and L shaped baseplates
03-01-2013 04:26 AM in reply to: jamalsid
No, it not. The only available offset is for a pinned column base according to CM66 code.
Artur Kosakowski
Active Contributor
jamalsid
03-01-2013 04:33 AM in reply to: Artur.Kosakowski
Artur
Thanks for the quick reply. I don't suppose you know if it is on the development roadmap at some point in the future do you? If not is it possible to add it to a wish list of new features/funtionality for a future version?
Product Support
Rafal.Gaweda
03-01-2013 04:49 AM in reply to: jamalsid
