Baseplate with eccentric column and L shaped baseplates
3 REPLIES 3
2505 Views, 3 Replies
Hello
Is it possible to use Robot's connection design module to design steel column baseplates where the columns are eccentric to the plate centre?
I also have a scenario with an L-shaped base plate and can't see a way to design this in robot eithre?
I have attached a drawing showing the base plate layouts I would like to verify in Robot.
3 REPLIES 3
Artur.Kosakowski
No, it not. The only available offset is for a pinned column base according to CM66 code.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
in reply to: Artur.Kosakowski
Artur
Thanks for the quick reply. I don't suppose you know if it is on the development roadmap at some point in the future do you? If not is it possible to add it to a wish list of new features/funtionality for a future version?
Rafal.Gaweda
