Discussion Groups
Robot Structural Analysis
Distinguished Contributor
mpcloob
Accepted Solution
Base Plate Design in Robot Structural Analysis Professional
1009 Views, 8 Replies
02-09-2013 02:19 AM
in the name of  GOD .
hello to all
I don't know how design Base Plate for steel columns in Robot Structural Analysis Professional ?
did you ever do it ?
Please use plain text.
Valued Mentor
AJA14
Re: Base Plate Design in Robot Structural Analysis Professional
02-10-2013 03:16 AM in reply to: mpcloob
Simply select your column and go to the connections design module and choose if it is pinned or fixed.
Regards.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
mpcloob
02-13-2013 09:38 AM in reply to: AJA14
I've done as you said but instead of base plate, column to beam is designed.
Robot can never base plate design?
please help me more
Product Support
Artur.Kosakowski
02-13-2013 11:53 PM in reply to: mpcloob
If you want to create a column base connection you need to select the column and as well as the node where you defined a support as shown on the attached picture.
Artur Kosakowski
mpcloob
02-14-2013 03:14 AM in reply to: Artur.Kosakowski
I did as you said and select column and node but the base plate connection is'n calculate for column.see attached image.:smileysad:
Product Support
Artur.Kosakowski
02-14-2013 03:26 AM in reply to: mpcloob
I assume that actually you created the connection as  a stand alone one using the button from the right hand side vertical toolbar rather than imported it from a model. In such case use the indicated button to run verification for manually entered set of forces.
Artur Kosakowski
mpcloob
02-14-2013 03:44 AM in reply to: Artur.Kosakowski
is there any way to design base plate connection for column that imported from a model ?
I can't do this. the same attached image in previous reply appears.:smileysad:
Product Support
Artur.Kosakowski
02-14-2013 04:16 AM in reply to: mpcloob
Try to follow the steps shown on the attached picture. Define a column (use any I section type), then add support. Select both the column and the node where you defined the support. Press the button indicated in blue.
Artur Kosakowski
mpcloob
02-14-2013 04:24 AM in reply to: Artur.Kosakowski
very nice. very good.very well . thank you
it's OK. Thanks for your quick reply really :smileytongue: :smileywink:
