Hi everyone.
I would like to know if anyone can tell me if it is possible to automatically transform a series of bars into links.
Alex
Solved by Rafal.Gaweda. Go to Solution.
Example macro attached.
Selected bars in Robot will be converted onto full rigid links
Thank you very much!
Now I am still a new user of robots, but I would like to know if I can create by myself an application
like the one you sent me.
Is there a manual to learn?
Check this thread: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Programming-Revit-and-Robot/td-p/.UNyxWG-Iet...
Hi Rafal,
Could you confirm that now it is impossible to create trough API multiple rigid links with the common master node?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Really?
I'm trying to do the same by API
Roman Zhelezniak
I have found solution. Thanks!
Roman Zhelezniak
Dim RLS As RobotNodeRigidLinkServer Set RLS = RobApp.Project.Structure.Nodes.RigidLinks RLS.Set 7, "3to6", "rl_fixed"
Hi Rafal,
Can you update the API macro to create Compatible nodes between bars end nodes instead of Rigid links?
I have about 1000 nodes that need to be linked in a nonlinear behavior and I could not find away other than copying the nodes with the Drag option so as to create bars, and then use the API to create a compatible link between the end points of each bar.
Just for your info, I am using it with Solid/volumetric structure design module.
@Rafal.Gawedacould you please explain how this sheet works?
I have selected a closed boundary of bars in RSAP and run your macro but I always get the message: "Decide - RL will not be created".
Could you explain or create a video please? Thanks!
