Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Bar spacing problem
11 REPLIES 11
Message 1 of 12
476 Views, 11 Replies
Bar spacing problem
Hi
I was designing a simple beam with relative high load but  the bars layers is stick to each ever , it should be at less 2.5 cm !
Knowing that i adjusted the preferred bar spacing Emin and Emax to 2.5 cm
please help me to solve this
a picture is attached
11 REPLIES 11
Message 2 of 12
Leader_Mohamed
export to autocad and adjust the layers there.
Message 3 of 12
in reply to: Leader_Mohamed
No , it seems to be an error in the programSmiley Indifferent
Message 4 of 12
Leader_Mohamed
any way you will send the drawing to AutoCAD to add spacer then readjust the reinforcement there.
Message 5 of 12
Leader_Mohamed
share your file and I'll test the problem occurs with me or not.
Message 6 of 12
Thank you my good friend
I know that I can adjust that in the autocad but the program must give me the right space between bars layers
I attached the file
Message 7 of 12
Artur.Kosakowski
Try to switch the indicated option off
Artur Kosakowski
Message 8 of 12
It didn't work either
I think that is an error in the program , and the developer should take into consideration
here is the file
Message 9 of 12
Hi Artur,
I checked this in 2014 and unchecking the Group Layers option appears to not work in 2014 either.  I have a test file I can send if it helps.
Looking forward to your diagnosis as this has been a quandry of mine.
-Ken
Message 10 of 12
As a temporary work-around, you can (I believe) adjust the Z spacing for the bar group as shown here.
It's a manual process but Robot will recalculate the capacity of the member with the adjusted spacing you provide.
from the General tab you can click the row of this rebar group and then switch to the spacing tab to adjust this value for
all of these bars in the member.  Note that this will turn on the "Freeze Reinforcing" option (because you manually edited it)
so be careful if you need to recalculate the beam, you will need to uncheck "Freeze Reinforcing" again.
Obviously the best scenario is that Robot will accurately place these bars so that the calculations are correct (often if you move this layer up
the capacity will no longer be adequate!)
Message 11 of 12
Artur.Kosakowski
We will investigate this situation. As ACI is not the code I'm vary familiar with - are we looking for 1 inch clear distance between the bottom and top layers of bottom rebars?
Artur Kosakowski
Message 12 of 12
in reply to: Artur.Kosakowski
Hi Artur,
Yes, you are correct.  ACI 318-08 (at least) says:
Where parallel reinforcement is placed in two
or more layers, bars in the upper layers shall be placed
directly above bars in the bottom layer with clear
distance between layers not less than 1 in.
Though there are some provisions for "bundled bars" where up to 4 bars may be used in contact if enclosed in stirrups or ties.  I assume that is the functionality of "group layers".
Thanks for looking into this,
-Ken
