Either you are looking for this:
or just open Displacement table filtered to selection of these nodes.
Not possible to see bar ends rotations in easy way.
This way : add node near the end you want to check rotations:
or in case of having release on such end you can do it this way:
Rafal, Using compatible nodes wouldn´t solve this problem?
Rafael Medeiros
It should in this case. I have not checked it but one node should belong to one bar, the second to the other bar
In general it depends on number of bars connected in one node because compatibility generates only one = second node .
Additionally: compatibility dofs are defined in Global CS
