Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Bar Releases (API) - Connection Rigidity Analysis
3 REPLIES 3
405 Views, 3 Replies
I've done a program for my thesis, dimension steel connection Column-Beam.
But i have a problem, I want to create bar release using API macro in Excel, to apply the Value Rigidity at node.
I Know create bar release (after verification steel connection) but i don`t know applying the value Rigidity "13000" kN/m (picture), by connection semi-rigid. In my code i don`t have apply the value. What is the problem?
After apply the value rigidity i need to calculate and see the variation of diagrams of bars.
I need your help
Code:
Sub Rigidity_Click()
Set RobApp = New RobotApplication
    Dim RLabel As RobotLabel
    Dim RelData As RobotBarReleaseData
    Dim EndData As RobotBarEndReleaseData
    Const rigidity As Double = 13000
    Set RLabel = RobApp.Project.Structure.Labels.Create(I_LT_BAR_RELEASE, "Teste dissertação")
    Set RelData = RLabel.Data
    Set EndData = RelData.StartNode
    EndData.Ry = I_BERV_ELASTIC = rigidity
    Set EndData = RelData.EndNode
    RobApp.Project.Structure.Labels.Store RLabel
End Sub
3 REPLIES 3
Rafal.Gaweda
Example code
    Set RLabel = RobApp.Project.Structure.Labels.Create(I_LT_BAR_RELEASE, "MY RELEASE")
    EndData.UX = I_BERV_ELASTIC
    EndData.KX = 10000
    EndData.UY = I_BERV_ELASTIC
    EndData.KY = 20000
Rafal Gaweda
in reply to: Rafal.Gaweda
Thanks!
Yes it did.
I've already applied  the value Rigidity, after calculate my steel connection.
