I am looking for the Robot Verification Manual as well as a theory manual, particular with reference to the finite elements in robot.
Solved by Artur.Kosakowski. Go to Solution.
The verification manual can be found in en-US\Manuals\Verification manuals folder on Robot DVD.
Surface elements – 3 node triangles (T3) and 4 node quadrilaterals (Q4)
[1] - IBRAHIMBEGOVIC A., WILSON E.L.,
A unified formulation for triangular and quadrilateral flat shell finite elements with six nodal degrees of freedom . Communications in Applied Numerical Methods.Vol 7, 1-9(1991)
[2] - KATILI I.,
A new discrete Kirchoff - Mindlin element based on Mindlin - Reissner
plate theory and assumed shear strain fields -Part I: An extended DKT element for thick -plate bending analysis. International Journal For Numerical Methods In Engineering , Vol 36, 1859-1883 (1993)
[3] - KATILI I.,
A new discrete Kirchoff - Mindlin element based on Mindlin -Reissner
plate theory and assumed shear strain fields -Part II: An extended DKQ element for thick -plate bending analysis. International Journal For Numerical Methods In Engineering, Vol 36, 1885-1908 (1993)
Try to find the path of c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\Documents\Verification manuals\
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
What type of shell element is used in Autocad Robot Structural Analysis Professional
2013 calculations? Is it maybe the Discrete Kirchoff – Mindlin Quadrilateral
finite shell element??
Plane elements – 3 node triangles (T3) and 4 node quadrilaterals (Q4)
[2] - KATILI I.,
[3] - KATILI I.,
I cannot find verification manual in Robot 2014 folders...
I cannot find verification manual in Robot 2014 folders too.
Can somebody give me a link to download the manual???
Please use this link http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13093279 or:
Roman Zhelezniak
Thanks Romanich!
I naively thought that Autodesk will publish new manuals for new 2014 version. 😞
I just stumbled upon this post. Until 2013, the verification manuals were put on the DVD. They have since been removed due to space.
The Verification Manuals can now be found on the autodesk.com website under Support and Learning.
Here is a direct link:
www.autodesk.com/rsapro-verification-manuals
I hope this helps.
