I have recently installed Robot 2010 in my computer. When I click on the support icon it does not display all the support cases . Normally there are varity of supports (i.e Pin/Fixed) available to use. Can anybody help me to sort this problem.
Many Thanks
Solved by Pawel.Pulak. Go to Solution.
availability of pre-defined supports may depend on regional settings of Robot. If they are not available the easiest solution is to define them using "New support definition" icon
