Good Morning All,
I recently downloaded the Autodesk Robot Professional 2015 30 day free trial with the hope to investing in it in the future. I am trying to model a three level over basement reinforced concrete structure in three dimensions. I have managed to input my basement support structure (consisting of load bearing walls and columns and walls) and my Ground floor structure (consisting of a flat slab). I analysed it for self weight only and checked the axial forces in the solumns and walls against hand calculations and the results were relatively consistent. However, I have somehow managed to mess up the display setting so I cannot see my structure properly any more. All I can see are the panel outlines and the columns if I set the section shapes to on (see attached screenshot). I cannot see the finite element mesh, the panel infills, or any results. I have messed around with the displaty settings but I cannot seem to get it right . I', sure it is probably something simple but being an inexperienced Robot user I would greatly appreciate some help.
P.S. I have attached screenshots showing all my current display settings.
Anthony McTigue
FMG Engineering
Level 1/2 Domville Avenue,
Hawthorn, VIC 3122
Solved by Rafal.Gaweda. Go to Solution.
