Hi
In Autodesk Concrete Building Structure 2011
How can I enable the option to find the center of torsion of the building?. After run the analysis the option to view the center of torsion and gravity are disable.
It is possible to find the center of torsion in Robot Structural Analysis?
Solved by jad.dellel. Go to Solution.
Please use the RSA forum to post question about RSA and ACBS:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/bd-p/351
If you use the 3rd method of calculation (F.E.M) and Dynamic analysis you should have access to G and T
On RSA, You've to choose Stories-> values
and :
