Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 12
NADJIB_36153615
715 Views, 11 Replies
Assemblage
voila  j ai un petit souci  avec  robot version 2010  ET 2013  pour le calcul  de l'assemblage des barres  gosset  ancrage  .....  en  fait  j  ai   procedé  avec  la methode indiqué  dans  le help    en selectionnant     par  exemple  le  noeud  et  la barre afferante  et  j utilise  l option   assemblage  une  fois  le  progamme lance  j aurai une nouvelle fenetre  ou il apparait  l'assemblage  mais  pas  la boite de dialogue  definition de l'assemblage   ( qui devrait souvrir automatiquement )   de ce fait  je  n arrive pas  a  modsifier  quoi  ce soit   par  exemple  le  diametre  du scelement  sans  cette boite  je ne peut rien faire
11 REPLIES 11
Message 2 of 12
Tags (1)
Message 3 of 12
Is that for existing models only or for a new project too?
Artur Kosakowski
Message 4 of 12
Les deux pour un projet existant   et  un  nouveau   j ai essayé  ca  ne marche pas
Message 5 of 12
Please try to uninstall and install Robot again.
Artur Kosakowski
Message 6 of 12
Yes  i have  unistalle  the  soft   an  i have install it aigain   , but  it s the  same  problem  but  when i have  install  robot  v2011   the problem   disparaite
Message 7 of 12
I'm not sure if I understand the situation correctly. My assumption is that you unistalled  Robot 2013 and then you installed it again but still the dialog with the geometry of the connection was not displayed. Then you installed Robot 2011 and now the dialog is visible in version 2013 too.
If yes, then can this be accepted as the solution?
Artur Kosakowski
Message 8 of 12
Don't  the  version of robot  2013   but   the version  2010   , and  with  the version  of  version 2013   don't  work stil   i  don't know   why  i think   that  the  problem  in  the registre
Message 9 of 12
Make sure you have the rights to modify the registry. Navigate to the EXE folder of Robot version where you can open the connection dialog and run "robot / unregserver". Then do navigate to the EXE folder of Robot where the connection dialog is not displayed and run "robot / regserver".
Artur Kosakowski
Message 10 of 12
Please  dans  quel  répertoire   le  repertoire  d'installation  de   robot  ou   dans le registre   alors  dans  quel  cléHKEY_LOCAL_MACHINE  ou bien HKEY_CURRENT_USER ou bien HKEY_USERS
than you
Message 11 of 12
Artur Kosakowski
Message 12 of 12
BONJOUR
I have do  what  you have  given in the  answer  but   it  still  don ' t  work  i don'i know   why
 thank you
