Hi all
I have a few questions
1)
I am quite new to Robot and need help with some graphical interface. I have used advanced options to determine the support to my structure and made it a rectangular column support. I was wondering if it is possible to show the support as a column instead of the simple support icons?
2)
I would like to know if it is possible to draw a landscape for the structure instead of the "structure presentation" since the ground is not completely flat . I have tried to convert the Robot file to Revit Structure but it seems like the overlapping beams is simply not displayed when doing so, and therefore using Revit Structure to create drawings seems inefficient.
I am doing something wrong or is the only way simply to redraw the entire structure in AutoCad ?
Attachment 1: Robot model
Attachment 2: The support definition
Attachment 3: Revit Structure model
Best Regards
Mark
Hi
Supports displayed shown below ; other types as you mentioned:
Landscape - in Revit or this one in Robot.
It is possible to save vrml file (but still flat)
Shortenings in RST - play with start \ end extension
