Is there a way to implement / add new parametric typical structure as offered in the default menu of robot ? (same menu where you can save or export sub-structure)
If possible, how do we do?
location of the files in RSA folder ?
code ?
etc ...
thanks a lot.
TS
Solved by Rafal.Gaweda. Go to Solution.
Files *.lib are located in the folder c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2014\System\Cfg\Lib\. You can open it by notepad, for example.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Possible but the procedure has not been used for last years so I do not know if it is even working.
I suggest to write it using API and add to Add-Ins menu.
