Adding parametric typical structure
2 REPLIES 2
t.sautierr
420 Views, 2 Replies
Is there a way to implement / add new parametric typical structure as offered in the default menu of robot ? (same menu   where you can save or export sub-structure)
If  possible, how do we do?
location of the files in RSA folder ?
code ?
etc ...
thanks a lot.
TS
2 REPLIES 2
Romanich
in reply to: t.sautierr
Files *.lib are located in the folder c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2014\System\Cfg\Lib\. You can open it by notepad, for example.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Rafal.Gaweda
Possible but the procedure has not been used for last years so I do not know if it is even working.
I suggest to write it using API and add to Add-Ins menu.
Rafal Gaweda
