The footfall and modal analysis only take the structures deadload into consideration. I want to add an extra permament load that the calulation should consider sinse heavy permanent equipment will be placed on the floor. Have tried to add extra permanent load without any change in the result.
Is it possible? How in that case?
Solved by Artur.Kosakowski. Go to Solution.
You should convert this load into dynamic mass
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
