Hi guys,
When I choose equivalent static method to AS1170.4, which weight is Robot including in the analysis?? I can't find any place where I can specify the weight that is used. I'm assuming it's DL1? Or just self weight?
Please advise.
Tony
Solved by Pawel.Pulak. Go to Solution.
Hi Tony,
in this type of analysis the mass resulting from self-weight is considered. Moreover it is considering added masses or load to mass conversion declared as "Global" or "Dynamic".
If this post answers your question please click "Accept as Solution". It will help everyone to find answer more quickly!
