Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
(API) macro for correcting nodes position by defining the path
9 REPLIES 9
Message 1 of 10
igos
2979 Views, 9 Replies
Hello, collegues!
Sometimes there is the situation (espessially if model was exported from Revit) when nodes which have to be located in the same plane are not fulfil this condition and this provide some problems (for example, Robot cannot distribute load from cladding, etc.)
In this situation you can use standart Robot tool - Advanced correction, but it moves nodes into the plane only by surface normal and in case of not orthogonal geomentry some adjoined parts of model can be hurted (like chain reaction).
So, I've tried to make some macros that correct nodes geometry and moves them into the plane by defined path.
For better understanding of macros' idea I've made a two short videos that shows differences between standard Robot tool (Robot Correction.wmv) and correction with macros (Excel Correction.wmv).
You can download them by link: http://www.4shared.com/zip/JJ4sdOmace/PLANE_CORRECT.html
Feel free to download and use, comments and modifications!
_________________________________________
https://ru.linkedin.com/in/igor-saltykov-8a68b726
9 REPLIES 9
Message 2 of 10
Rafal.Gaweda
in reply to: igos
Nice, added to addin list
Rafal Gaweda
Message 3 of 10
balintus03
in reply to: igos
Thank you for the API!
I really would like to see the videos that you have made but the link is not available anymore. Is there way to share again with us. Thank you in advance!
Message 4 of 10
ALEXTHAINESE
in reply to: igos
the addin link is not avalaible for download- can you update the link
Message 5 of 10
Rafal.Gaweda
in reply to: ALEXTHAINESE
Hi @ALEXTHAINESE
Addin \ macro \ xls is attached in first post. It is working.
Link to video is dead only.
Rafal Gaweda
Message 6 of 10
Romanich
in reply to: igos
Hi @igos,
Stole your macro and add the possibility to define the origin of the path for correction using local X axis of the selected bar. The modified macros attached.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 7 of 10
igos
in reply to: Romanich
Hi @Romanich,
You are welcome!
Message 8 of 10
m_sheinin
in reply to: igos
Thank you,
Can you show how to use this macro ?
Message 9 of 10
Romanich
in reply to: m_sheinin
Hi @mike.sheinin
Roman Zhelezniak
Message 10 of 10
m_sheinin
Thanks, Great explanation.
