Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
API - get load combination properties
19 REPLIES 19
Message 1 of 20
Mirko.Jurcevic
1911 Views, 19 Replies
I am trying to get code combination properties, but I can't get it, i've made this so far:
public partial class Form1 : Form
     IRobotCaseServer Loads;
     RobotCaseCollection RCC;
     private void Form1_Load(object sender, EventArgs e) {
          Robot.robApp = new RobotApplication();
          Loads = Robot.robApp.Project.Structure.Cases;
          RCC = Loads.GetAll();
          for (int j = 1; j <= RCC.Count; j++) {
                 IRobotCase rc = RCC.Get(j);
                 IRobotCaseAnalizeType AT = rc.AnalizeType;
                 if (AT == IRobotCaseAnalizeType.I_CAT_COMB || AT == IRobotCaseAnalizeType.I_CAT_COMB_CODE || AT == IRobotCaseAnalizeType.I_CAT_COMB_NONLINEAR) {
                 //IRobotCaseCombination RComb = RCC.Get(j); //this doesn't work
                 IRobotCaseCombination RComb = RCC.Get(j) as IRobotCaseCombination; //this doesn't work also
                 textBox1.Text += rc.Number + " " + rc.Name + "\r\n";
                 textBox1.Text += RComb.label + "\r\n"; //this doesn't work, loop breaks here
                 // textBox1.Text += RCC.Get(j).label + "\r\n"; //this doesn't work also
But this code seem to work in excel. I don't understand. Here is the main problem:
it won't accept it.
and this line returns null reference:
any idea?
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
19 REPLIES 19
Message 2 of 20
Because code combinations are not combinations
                    RobotCodeCmbCombs RCombs = RCC.Get(j);
                    for (int ii = 1; ii <= RCombs.Count; ii++)
                        RobotCodeCmbComponent RC = RCombs.Get(ii,........);
Rafal Gaweda
Message 3 of 20
I know that I've been missing something, thanks Rafal, but that's not working either.
I've tried this:
RobotCodeCmbCombs Combinations = RCC.Get(j);
textBox1.Text += Combinations.Count.ToString() + "\r\n";
 and this:
RobotCodeCmbCombs Combinations = RCC.Get(j) as RobotCodeCmbCombs;
 and this:
IRobotCodeCmbCombs Combinations = RCC.Get(j) as IRobotCodeCmbCombs;
 but code breaks at this line:
 By breaking, I mean it keeps running but it does nothing.
Mirko Jurcevic
Message 4 of 20
MIrko
are you sure Get(j) returns codecombination and not manual combination ?
try switch:
switch (AT)
case IRobotCaseAnalizeType.I_CAT_COMB:
IRobotCaseCombination RComb ...
break;
case IRobotCaseAnalizeType.I_CAT_COMB_CODE
RobotCodeCmbCombs RCombs ......
Rafal Gaweda
Message 5 of 20
I have 0 manual combinations.
It still doesn't work.
I have this:
RobotCaseCollection RCC = Robot.robApp.Project.Structure.Cases.GetAll();
        switch (AT) {
			textBox1.Text += "not a code combination";
			break;
		case IRobotCaseAnalizeType.I_CAT_COMB_CODE:
			textBox1.Text += "i'm in";	//this is printed only once
		break;
 I am not sure if this is ok:
Mirko Jurcevic
Message 6 of 20
My mistake, sorry.
Correct code:
RobotCaseCollection RCC = Loads.GetAll();
            IRobotCase RC = RCC.Get(j);
            IRobotCaseAnalizeType AT = RC.AnalizeType;
              RobotCodeCombination c = RCC.Get(j);
              MessageBox.Show(c.Number.ToString() + " " + c.Name);
              RobotCodeCmbComponentMngr RCombs = c.Components;
                IRobotCodeCmbComponent RComp = RCombs.Get(ii);
                for (int jj = 1; jj <= RComp.Count; jj++)
                  RobotCodeCmbFactor factor = RComp.Get(jj);
                  string cn = factor.CaseNumber.ToString();
                  string fc = factor.Factor.ToString();
                  MessageBox.Show(cn + " " + fc);
                //textBox7.Text += RC.Number.ToString();
Rafal Gaweda
Message 7 of 20
Yes, it works !!
Thank you Rafal, very much. It would took me several days to figure it out myself !
Cheers!
Mirko Jurcevic
Message 8 of 20
Eh, another problem I have now...  Smiley Indifferent
What in case I have moving load in combinations?
I have it and I get '0' for case number (cn variable) in such case:
for this: 1*1.35 + 3*0.90 + 4*0.75 + 5/12*1.50
I get this: 1*1.35 + 3*0.90 + 4*0.75 + 0*1.50
etc.
What I want to do is get load definition for all cases, then replace those case numbers with case labels (for my custom report application).
Mirko Jurcevic
Message 9 of 20
Most likely moving load cases not implemented there.
We will check tomorrow.
Rafal Gaweda
Message 10 of 20
Is there any other way to get combination definition "sentence"?
Because, that's all I need.
Mirko Jurcevic
Message 11 of 20
If you mean "Definition" - Definition column in Combinations table : try to open Combinations table (by API), set display of code combinations, (maybe set case also) then save to text file \ csv then read this file in your program.
Rafal Gaweda
Message 12 of 20
Yes, I've already tried this, I managed to open table but I didn't know how to get data from table rows.
Can I somehow "copy" data from table "Definition" column (I mean without saving as txt or csv file)?
I not, how to save it to txt through api?
Mirko Jurcevic
Message 14 of 20
Thanks Rafal !
I shall try to adjust it for my app.
Mirko Jurcevic
Message 15 of 20
Rafal, this is great stuff.
C# code is pretty simple, I'll post it here, maybe it help someone else:
using System;
using System.IO;
private void Save_Table() {
	string FolderName = "Intelika";
	IRobotTable RT = Robot.robApp.Project.ViewMngr.CreateTable(IRobotTableType.I_TT_COMBINATIONS, IRobotTableDataType.I_TDT_CODE_GROUPS);
	/*** path to desktop: ***/
	string path = Environment.GetFolderPath(Environment.SpecialFolder.Desktop);
	path += "\\" + FolderName;
	if (!Directory.Exists(path))	/*** if directory doesn't exists -> create it ***/
		Directory.CreateDirectory(path);
	RT.Printable.SaveToFile(path + "\\temp.html", IRobotOutputFileFormat.I_OFF_HTML);	/*** SAVE AS HTML ***/
	RT.Printable.SaveToFile(path + "\\temp.txt", IRobotOutputFileFormat.I_OFF_TEXT);	/*** SAVE AS TXT ***/
I didn't know about this SaveToFile() method before.
This approach is much much faster than reading combinations directly from Robot. Good to know!
But, as always, I have yet another question.  😉
Now that I've opened and exploited Robot's table, can I somehow close it through api?
I don't want 20 tables opened in Robot every time I extract some data.  😞
Mirko Jurcevic
Message 16 of 20
Check this example:
RobotTableFrame tf = robApp.Project.ViewMngr.GetTable(1);
          tf.Window.SendMessage(0x0010,0,0) ;
OR
RobotTable RT = robApp.Project.ViewMngr.GetTable(1);
          RT.Window.SendMessage(0x0010,0,0) ;
 In VB, VBA:
RT.Window.SendMessage 16, 0, 0
Rafal Gaweda
Message 17 of 20
Yep, it works!
Very nice, thanks!
Mirko Jurcevic
Message 18 of 20
Visual studio complains: "Cannot implicitly convert RobotTable to RobotTableFrame" or something like that
And I must comment this code:
          tf.Window.SendMessage(0x0010,0,0);
Very dangerous if you run this code in some view where you have tables opened (for example in "Loads" interface you have Load table opened by default and user cannot close it, but API can), it closes first table it finds, and that can be some other table than the one API opened.
I've programmed to find last opened table.
This works fine:
int numOfTables = Robot.robApp.Project.ViewMngr.TableCount;
IRobotTableFrame tf = Robot.robApp.Project.ViewMngr.GetTable(numOfTables);
tf.Window.SendMessage(0x0010, 0, 0);
Mirko Jurcevic
Message 19 of 20
Dim RT As RobotTable
Dim RTF As RobotTableFrame
Set RTF = Robapp.Project.ViewMngr.GetTable(1)
Set RT = RTF.Get(1)
Rafal Gaweda
Message 20 of 20
That's cheating  😉
Mirko Jurcevic
