Discussion Groups
Robot Structural Analysis
Active Contributor
Accepted Solution
(API) VBA of definition ( uniform planar load and Uniform Load)
339 Views, 11 Replies
07-03-2012 07:28 AM
Hi. . I reading API Load definition but I understan.Please given file VBA uniform planar load and Uniform Load
Thanks you.
Please use plain text.
Active Contributor
Re: VBA of definition ( uniform planar load and Uniform Load)
07-03-2012 08:45 AM in reply to: nhandayasd
I don't known if i get your problem. With a little help with "Getting Started Guide Robot API", you can get there...
See the attached file. Of course you need to make your code more robust, than I have in this example, but it is a start point.
Regards
Active Contributor
07-03-2012 09:28 AM in reply to: nhandayasd
Thanks.
so you do it.
Product Support
07-03-2012 11:48 PM in reply to: nhandayasd
I do not understand.
Check additional two buttons in attached xls.
Rafal Gaweda
Active Contributor
Re: (API) VBA of definition ( uniform planar load and Uniform Load)
07-04-2012 07:13 AM in reply to: nhandayasd
yes. Great.
THanks you.
Distinguished Contributor
09-17-2012 09:46 PM in reply to: nhandayasd
Thanks.
Please write API given Uniform Load.
09-18-2012 02:15 AM in reply to: A.wikipedia
RG_Adsk
Product Support
09-18-2012 03:09 AM in reply to: A.wikipedia
Private Sub CommandButton2_Click()
Dim Robapp As RobotApplication
Set Robapp = New RobotApplication
Dim Loads As RobotCaseServer
Set Loads = Robapp.Project.Structure.Cases
Dim Cas As RobotSimpleCase
Dim Recs As RobotLoadRecordMngr
Dim Rec_1 As RobotLoadRecord
CaseNumber = 1
Set Cas = Loads.Get(CaseNumber)
Set Recs = Cas.Records
Recs.New I_LRT_BAR_UNIFORM
Set Rec_1 = Recs.Get(Recs.Count)
Rec_1.Objects.FromText "1"
Rec_1.SetValue I_BURV_PY, 3.23
End Sub
Rafal Gaweda
09-18-2012 06:32 AM in reply to: Rafal.Gaweda
Thanks RG_Adsk.
But erro.
You can do same file VBA of uniform planar.
Product Support
09-19-2012 01:51 AM in reply to: A.wikipedia
File attached.
Next time you will write code, I will correct if needed.
Rafal Gaweda
