(API) VBA of definition ( uniform planar load and Uniform Load)
11 REPLIES 11
Message 1 of 12
nhandayasd
1023 Views, 11 Replies
Hi. . I reading API Load definition but I understan.Please given file VBA uniform planar load and Uniform Load
Thanks you.
11 REPLIES 11
Message 2 of 12
rsousa_
in reply to: nhandayasd
I don't known if i get your problem. With a little help with "Getting Started Guide Robot API", you can get there...
See the attached file. Of course you need to make your code more robust, than I have in this example, but it is a start point.
Regards
Message 3 of 12
nhandayasd
Thanks.
so you do it.
Message 4 of 12
Rafal.Gaweda
I do not understand.
Check additional two buttons in attached xls.
Rafal Gaweda
Message 5 of 12
nhandayasd
yes. Great.
THanks you.
Message 6 of 12
A.wikipedia
Thanks.
Please write API given Uniform Load.
Message 7 of 12
A.wikipedia
in reply to: A.wikipedia
RG_Adsk
Message 8 of 12
Rafal.Gaweda
Private Sub CommandButton2_Click()
Dim Robapp As RobotApplication
Set Robapp = New RobotApplication
Dim Loads As RobotCaseServer
Set Loads = Robapp.Project.Structure.Cases
Dim Cas As RobotSimpleCase
Dim Recs As RobotLoadRecordMngr
Dim Rec_1 As RobotLoadRecord
CaseNumber = 1
Set Cas = Loads.Get(CaseNumber)
Set Recs = Cas.Records
Recs.New I_LRT_BAR_UNIFORM
Set Rec_1 = Recs.Get(Recs.Count)
Rec_1.Objects.FromText "1"
Rec_1.SetValue I_BURV_PY, 3.23
End Sub
Rafal Gaweda
Message 9 of 12
A.wikipedia
in reply to: Rafal.Gaweda
Thanks RG_Adsk.
But erro.
You can do same file VBA of uniform planar.
Message 10 of 12
Rafal.Gaweda
File attached.
Next time you will write code, I will correct if needed.
Rafal Gaweda
Message 11 of 12
rsousa_
I absolutely agree with you Rafal.
This is a place to help others, not to do their job, without any effort from their side!
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Best regards
Message 12 of 12
A.wikipedia
in reply to: rsousa_
Thanks.
I to try.
