Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
(API) VBA ROS - running steel code calculation
21 REPLIES 21
Message 1 of 22
Adamchuk_Nicolay
1642 Views, 21 Replies
please help me with next problem:
how running calculation for steel members using VBA (Robot Open Standart).
Unfortunatly not any example for this case.
21 REPLIES 21
Message 2 of 22
Nicolay,
Check pdf in message 2 here: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Manual-Calculations-for-Steel-Design-using-A...
Example from page 95
Two small examples of creating steel design groups and geting steel design ratio attached
Rafal Gaweda
Message 3 of 22
Rafal.Gaweda
in reply to: Rafal.Gaweda
example of creating steel design label for bars
Rafal Gaweda
Message 4 of 22
Rafal.Gaweda
Message 5 of 22
How can I create a Code group, and specify the sections list and code parameters to use by each group using Robot API.
thanks
Message 6 of 22
Rafal.Gaweda
Example in message 2 of this thread.
Code parameters are assigned to bars , not design group
Rafal Gaweda
Message 7 of 22
in reply to: Adamchuk_Nicolay
I'm so sorry, but I didn't understand how to specify Section database and section families in your code. I saw how to include or exclude a member in Code Grup if you define all the parameters before. In my case I want to create a Code group at the first time without any definition before. Cold you help me?
thanks.
Message 8 of 22
Rafal.Gaweda
Code update for previous example
Dim RDMServer As RDimServer
    Dim RDMStream As RDimStream
    Dim RDMGrps As RDimGroups
    Dim RDMGrp1 As RDimGroup
    Dim RDmGrpProfs As RDimGrpProfs
    Set RDMServer = RobApp.Kernel.GetExtension("RDimServer")
    RDMServer.Mode = I_DSM_STEEL
    Set RDMGrps = RDMServer.GroupsService
    idx = 0
    While Cells(2 + idx, 1) <> Empty
        usrgr = Int(Cells(2 + idx, 1))
        Set RDMGrp1 = RDMGrps.Get(usrgr)
        RDMGrp1.Name = Cells(2 + idx, 2)
        Set RDMStream = RDMServer.Connection.GetStream
        RDMGrp1.GetMembList RDMStream
        RDMStream.Clear
        RSelection.FromText Cells(2 + idx, 3)
        Cells(2 + idx, 3) = RSelection.ToText
        RDMStream.WriteText RSelection.ToText
        RDMGrp1.SetMembList RDMStream
        Set RDmGrpProfs = RDMServer.Connection.GetGrpProfs
        RDmGrpProfs.Clear
        RDMStream.Clear
        RDMStream.WriteText ("IPE")           ' family of profiles
        RDMStream.WriteText ("HEA")           ' family of profiles
        RDmGrpProfs.SetFamilies "SIMPL", RDMStream ' section database
        RDMGrp1.SetProfs RDmGrpProfs
        RDMGrps.Save RDMGrp1
        idx = idx + 1
    Wend
Rafal Gaweda
Message 9 of 22
Thanks Rafal,
Again you were extremely efficient and attentive with me.
Message 10 of 22
Private Sub CommandButton2_Click()
On Error GoTo err
Set RobApp = New RobotApplication
If Not RobApp.Visible Then
Set RobApp = Nothing
MsgBox "Open Robot and load model", vbOKOnly, "ERROR"
Exit Sub
Dim RSelection As RobotSelection
Set RSelection = RobApp.Project.Structure.Selections.Create(I_OT_BAR)
Dim RDMServer As RDimServer ' Resultados
Dim RDMStream As RDimStream ' vetor com os parametros
Dim RDMGrps As RDimGroups ' De todos os grupos
Dim RDMGrp1 As RDimGroup ' Grupo em questão
idx = 0
usrgr = Int(Cells(2 + idx, 1)) ' Captura o valor do nome do grupo na primeira coluna da planilha
Set RDMGrp1 = RDMGrps.Get(usrgr) ' Seleciona qual grupo se pretende capturar as informações
RDMGrp1.Name = Cells(2 + idx, 2) ' Seta o nome do grupo com o valor da segunda coluna da planilha
Set RDMStream = RDMServer.Connection.GetStream ' vetor de parâmetros
RDMGrp1.GetMembList RDMStream ' Aloca as informções do grupo selecionado no vetor RDMStream
RDMStream.Clear ' Limpa o vetor
RSelection.FromText Cells(2 + idx, 3) ' Faz a seleção conforme preeechimento da 3 coluna da planilha
RDmGrpProfs.Clear
RDMStream.Clear
RDMStream.WriteText ("CW") ' family of profiles
RDMStream.WriteText ("CWN") ' family of profiles
RDmGrpProfs.SetFamilies "AISI", RDMStream ' section database
idx = idx + 1
Wend
Exit Sub
err:
If err.Number = 91 Then MsgBox "One of group number does not exist in model.Please check"
End Sub
I tested the code but it didn't work. On this example I was trying change the actual database to "AISI" and section families to "CW" and "CWN", but the code always Stop in this line
What am I doing wrong?
thanks
Message 11 of 22
Rafal.Gaweda
Try this (add this line to code, add database to list):
Rafal Gaweda
Message 12 of 22
It's working now. Thank you.
Sorry for asking so much things, but how can I list all Database and section families defined?.
Thanks again.
Message 13 of 22
Rafal.Gaweda
Message 14 of 22
I did this code to list all my section Database
Dim teste As IRobotSectionDatabaseList
Set teste = RobApp.Project.Preferences.SectionsFound
Dim sec_data As IRobotSectionDatabase
For I = 1 To teste.Count
Cells(16 + I, 1) = teste.Get(I)
Cells(16 + I, 2) = teste.GetDatabase(I).FullName
Next I
It appears more database than defined in my job preferences.
How it is possible? How can I select only steel and timber sections?
Message 15 of 22
Rafal.Gaweda
I think you are looking for:
SectionsActive ( see page 1232) The list of active (selected) section databases .
Rafal Gaweda
Message 16 of 22
Where can I find this Document?
I'm using Robot Open Standard 6.0 and there are only 452 pages.
Message 17 of 22
Thanks.
Now it´s working.
Message 18 of 22
I created this code to list the material and section database.
public void MaterialComboBox()
RobotNamesArray ListaMaterial;
RobotClass.Robot.Project.Preferences.Materials.Load ("American");
ListaMaterial = RobotClass.Robot.Project.Preferences.Materials.Get(IRobotMaterialType.I_MT_STEEL);
for (int i = 1; i <= ListaMaterial.Count; i++)
comboBox1.Items.Add(ListaMaterial.Get(i));
public void SecoesListComboBox()
IRobotSectionDatabaseList SecDataBase=RobotClass.Robot.Project.Preferences.SectionsActive;
ArrayList Catalogo = new ArrayList();
for (int i = 1; i <= SecDataBase.Count; i++)
checkedListBox1.Items.Add(SecDataBase.GetDatabase(i).FullName);
Catalogo.Add(SecDataBase.Get(i));
I didn't find how to list Families sections for each Database section.
Could you help me?
Message 19 of 22
Rafal.Gaweda
robapp.Project.Preferences.SetCurrentDatabase I_DT_SECTIONS, "AISI"
Dim SDL As RobotSectionDatabaseList
Set SDL = robapp.Project.Preferences.SectionsActive
Dim RSD As RobotSectionDatabase
For I = 1 To SDL.Count
    If SDL.GetDatabase(I).Name = "AISI" Then
        Set RSD = SDL.GetDatabase(I)
Next I
Dim Sections As RobotNamesArray
Set Sections = RSD.GetAll
Row = 10
Dim Familyname As String
Familyname = ""
For j = 1 To Sections.Count
If Familyname <> Left(Sections.Get(j), InStr(Sections.Get(j), " ") - 1) Then
    Familyname = Left(Sections.Get(j), InStr(Sections.Get(j), " ") - 1)
    Cells(Row, 1) = Familyname
    Row = Row + 1
Next j
Rafal Gaweda
Message 20 of 22
Hi Rafal,
I'm having problems in the following part. The error is attached.
Could you help me again?
//Definições das variáveis
RDimServer RDMServer; // Resultados
RDimStream RDMStream ; // vetor com os parametros
RDimGroups RDMGrps; // De todos os grupos
RDimGroup RDMGrp1; // Grupos atuais
RDimGroup RDMGrp2; // Grupo que será criado
IRDimGrpProfs RDmGrpProfs; // Code grups
RobotBar Elemento;
int num_elemento;
//Pega os elementos da linha do formulario
RobotSelection ElemSelecionado = RobotClass.Robot.Project.Structure.Selections.Create(IRobotObjectType.I_OT_BAR);
ElemSelecionado.FromText(textBox1.Text);
RobotBarCollection ElemColecao = (RobotBarCollection)RobotClass.Robot.Project.Structure.Bars.GetMany(ElemSelecionado);
//Checa se a seleção e valores de entradas
if (!ChecaSelecaoElemento(ElemSelecionado)) return; // Seleção de elementos
//Processo de criação dos grupos
RDMServer = RobotClass.Robot.Kernel.GetExtension("RDimServer");
RDMServer.Mode = IRDimServerMode.I_DSM_STEEL;
RDmGrpProfs = RDMServer.Connection.GetGrpProfs;
RDmGrpProfs.Clear();
