I have 2 loads working in z negative direction self weight (egenvikt) and dead load (nyttiglast). Deflection for the two loads displays correctly, but for my load case (Lastfall 1) it represents deformation upwards? If i read the values via api
Solved by Rafal.Gaweda. Go to Solution.
These combinations (7,8) should not be set as quadratic combinations:
