Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
API RSA - bars table
4 REPLIES 4
919 Views, 4 Replies
I would like to use API to open a .rtd file, get the bars table and collect information from it (for each bar, sart and end node, section, material, gamma angle, bar type). What is the syntax for that ?
Guillaume
4 REPLIES 4
Rafal.Gaweda
robotapplication.Project.Open
This way only by saving to csv file.
Example:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Exporting-modal-harmonic-load-case-getti...
http://forums.autodesk.com/t5/Robot-Structural-Analysis/ROBOT-API-VBA-Panel-cuts-and-table-generatio...
I suggest just to get bar collection and get data from there. Example for steel members:
Dim Bar As RobotBar
Dim Sec As RobotBarSection
Dim BarCol As RobotBarCollection
Dim Mat As RobotLabel
Dim BarType As RobotLabel
For i = 1 To BarCol.Count
    Set Bar = BarCol.Get(i)
    Set Sec = Bar.GetLabel(I_LT_BAR_SECTION)
    Set Mat = Bar.GetLabel(I_LT_MATERIAL)
    Set BarType = Bar.GetLabel(I_LT_MEMBER_TYPE)
    Cells((7 + i), 1) = Bar.Number
    Cells((7 + i), 2) = Sec.Name
    Cells((7 + i), 3) = Bar.StartNode
    Cells((7 + i), 4) = Bar.EndNode
    Cells((7 + i), 5) = Mat.Name
    Cells((7 + i), 6) = Bar.Gamma
    Cells((7 + i), 7) = BarType.Name
Rafal Gaweda
in reply to: Rafal.Gaweda
Thanks, I'll try this.
And to get results (displacements, forces, stresses, reactions, ...), which classes are to be used ?
Rafal.Gaweda
RobApp.Project.Structure.Results.Nodes.Displacements...
RobApp.Project.Structure.Results.Nodes.Reactions....
RobApp.Project.Structure.Results.Bars.Forces....
RobApp.Project.Structure.Results.Bars.Stresses...
Rafal Gaweda
Thanks.
