I would like to use API to open a .rtd file, get the bars table and collect information from it (for each bar, sart and end node, section, material, gamma angle, bar type). What is the syntax for that ?
Guillaume
Solved by Rafal.Gaweda. Go to Solution.
robotapplication.Project.Open
This way only by saving to csv file.
Example:
I suggest just to get bar collection and get data from there. Example for steel members:
Dim Bar As RobotBar Dim Sec As RobotBarSection Dim BarCol As RobotBarCollection Dim Mat As RobotLabel Dim BarType As RobotLabel ..... For i = 1 To BarCol.Count Set Bar = BarCol.Get(i) Set Sec = Bar.GetLabel(I_LT_BAR_SECTION) Set Mat = Bar.GetLabel(I_LT_MATERIAL) Set BarType = Bar.GetLabel(I_LT_MEMBER_TYPE) Cells((7 + i), 1) = Bar.Number Cells((7 + i), 2) = Sec.Name Cells((7 + i), 3) = Bar.StartNode Cells((7 + i), 4) = Bar.EndNode Cells((7 + i), 5) = Mat.Name Cells((7 + i), 6) = Bar.Gamma Cells((7 + i), 7) = BarType.Name
Thanks, I'll try this.
And to get results (displacements, forces, stresses, reactions, ...), which classes are to be used ?
