When using moving loads, Robot creates a load case called, for example, TruckLoad. After calculation, two additional cases are presented, TruckLoad+ and TruckLoad-, each containing the positive and negative results, respectively.
Is it possible to, knowing the general loadcase (TruckLoad), obtain the "+" and "-" cases? Obviously I could run through all of the cases and find them by the name, but I would like to know if there is a more direct method to do it. If there is a property to the general case which points to the others, for example. Is there such a thing?
Solved by Rafal.Gaweda. Go to Solution.
