Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
(API) ModelPoint coordinates set
1 REPLY 1
224 Views, 1 Reply
Hi.
I've been developing an API on which it is supposed to set the coordinates new coordinates for a modelpoint. I tried doing so thorught the folowing code:
Dim Robot as new Robotapplication
Dim panel as IRobotObjObject
Dim model_point_3d As IRobotGeoPoint3D
panel = Robot.Project.Structure.Objects.Get(1)
model_point_3d = panel.Main.Modelpoints.Get(3)
model_point_3d.Set(50, 50, 50)
The code actually runs but it has no effect and also returns no errors. I've also tried checking the modelpoint coordinates after running the "Set" command, and it actually returns "50,50,50" but once again it has no effect in the Robot interface, even after refreshing the viewport. Is there any workaround for this?
Thnaks in advance
1 REPLY 1
Rafal.Gaweda
Modelpoints has Get only
use .Main.Geometry to define \ update geometry
Example: http://forums.autodesk.com/t5/Robot-Structural-Analysis/VBA-Excel-macro-for-any-object-geometry-modi...
Rafal Gaweda
