Hello
I need to create and define manual combinations through API VBA code. Can anyone help me? The case i can create, but i am not sure what is the best way to do that and i don't know how to define the cases and factors to take into consideration.
Thanks in advance.
Solved by Rafal.Gaweda. Go to Solution.
Thank you very much....
@Rafal.Gaweda wrote:
Check this
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Editing-load-cases-in-excel-API/m-p/3929901#...
