(API) Macro for creating superbars \ supermembers in Excel table
Rafal.Gaweda
Autodesk Support Autodesk Support
Message 1 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
See attached file
Rafal Gaweda
Replies (9)
Message 2 of 10
t.sautierr
Marvelous as usual ....
Message 3 of 10
netsonicyxf
What' is superbar or supermember?
Message 5 of 10
RRufino
Hi Rafal,
This api seems very nice (as usual on your creations).
Is there a chance to import superbar from robot to edit them, and also read "Available Bar Types" on model? Almost like you did on api to create and edit load cases and combinations.
If you could to this mods they will be very useful.
RR
Message 6 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Here you are.
Rafal Gaweda
Message 7 of 10
RRufino
Thanks Rafal, 5* as expected.
Message 8 of 10
Rafacascudo
Is it supposed to also work with superbars created from trapezoidal loading??
I´m getting an error
Rafael Medeiros
Message 9 of 10
marcinrakus
Probably there is no MEMBER_TYPE label for this superbar. You may add If RBar.HasLabel(I_LT_MEMBER_TYPE) Then ... End If
Message 10 of 10
Rafacascudo
No API skills here Smiley Sad
thx anyway!
Rafael Medeiros
