Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
(API) IRobotDisplacementData
17 REPLIES 17
Message 1 of 18
jokiller70
372 Views, 17 Replies
I am trying to read back displacement data from robot to autocad via api. How do i use the UX, UY and UZ values correctly?
This is the code i use;
            For n = 1 To 10
                hej = fe_serv.Value(bar_num, cas_num, n / 10)
                värdet = 0
                value = deplace.Value(bar_num, n / 10 - 0.1, cas_num)
                value2 = deplace.Value(bar_num, n / 10, cas_num)
                For j = 0 To 2
                    startpoint(j) = aPoints(Bar.StartNode, j) + (aPoints(Bar.EndNode, j) - aPoints(Bar.StartNode, j)) * (n - 1) / 10
                    endpoint(j) = aPoints(Bar.StartNode, j) + (aPoints(Bar.EndNode, j) - aPoints(Bar.StartNode, j)) * n / 10
                    newvals(j) = value.UX * mtx(j, 0) + value.UY * mtx(j, 1) + value.UZ * mtx(j, 2)
                    newvals2(j) = value2.UX * mtx(j, 0) + value2.UY * mtx(j, 1) + value2.UZ * mtx(j, 2)
                    startpoint(j) = startpoint(j) - newvals(j) * 100000 / 4
                    endpoint(j) = endpoint(j) - newvals2(j) * 100000 / 4
                Next j
                oEnt = oExpDoc.ModelSpace.AddLine(startpoint, endpoint)
                aCol = oEnt.TrueColor
                aCol.ColorMethod = NtiMonzon.Interop.Acad.AcColorMethod.acColorMethodByRGB
                värdet = hej.Smax
                kolla = System.Math.Abs(värdet / mmmax)
                If kolla > -0.01 And kolla < 0.25 Then
                    R = 0
                    G = CInt(kolla * 4 * 255 / 4)
                    B = 255
                ElseIf kolla > 0.25 And kolla < 0.5 Then
                    R = 0
                    G = 255
                    B = CInt(255 - (kolla - 0.25) * 4 * 255 / 4)
                ElseIf kolla > 0.5 And kolla < 0.75 Then
                    R = CInt((kolla - 0.5) * 4 * 255 / 4)
                    G = 255
                    B = 0
                Else
                    R = 255
                    G = CInt(255 - (kolla - 0.75) * 4 * 255 / 4)
                    B = 0
                End If
                If Me.CheckBox1.Checked = True Then oExpDoc.SendCommand("_ZOOM" & vbLf & "_E" & vbLf)
                aCol.ColorIndex = 180 - CInt(kolla * 17) * 10
                oEnt.TrueColor = aCol
                data1 = Nothing
                cas = Nothing
            Next n
17 REPLIES 17
Message 2 of 18
Rafal.Gaweda
in reply to: jokiller70
See attached example macro
Rafal Gaweda
Message 3 of 18
jokiller70
in reply to: Rafal.Gaweda
Sorry, it is the bar displacements I want to get.
Message 4 of 18
Rafal.Gaweda
Message 5 of 18
Rafal.Gaweda
what is wrong with RobApp.Project.Structure.Results.Bars.Displacements.Value(....) ?
Rafal Gaweda
Message 6 of 18
jokiller70
Please look at the attached dwg. I can not figure out how to translate the values so they always comes as LCS.
Message 7 of 18
jokiller70
This is the model i try to calculate.
Message 8 of 18
Rafal.Gaweda
Have you looked at macro I had showed you?
Look at Sub PrintDisp(.....)
It converts displacements from GCS to LCS of bar
Rafal Gaweda
Message 9 of 18
jokiller70
Nu such sub in there. I figured out that i had a bar.gamma causing values to come out rotated. Still not sure if i have to include the nodal displacements to show a correct graph.
Message 10 of 18
Rafal.Gaweda
Message 4 link .....
Rafal Gaweda
Message 11 of 18
Rafal.Gaweda
Why do not you want to draw lines in GCS ?
Rafal Gaweda
Message 12 of 18
jokiller70
I am already doing the transformation in that macro, but when i have bar.gamma other than 0 I get strange values.
Message 13 of 18
Rafal.Gaweda
Gamma angle?
It rotates section around local X of bar.
Rafal Gaweda
Message 14 of 18
jokiller70
Yes so for gamma=90 I get value.UZ as value.UY
Message 15 of 18
Rafal.Gaweda
Yes , in case of one bar
If there are two or more bars meeting in one node and they have different gamma angles, different LCSes this may not be that easy I think. Try.
I suggest to use transformation matrix approach.
Rafal Gaweda
Message 16 of 18
jokiller70
Bam! Se how beautifull it looks! Again thanks alot.
Message 17 of 18
Rafal.Gaweda
Johan,
Congrats!
If you did not use matrix approach - check yours on inclined members
Rafal Gaweda
Message 18 of 18
jokiller70
I did use matrix approach, but had to rewrite du to different bar.gamma:s
