I’m having some issues exporting a set of data tables from Robot to Excel. I have some 48 tables I want to export, which correspond to 48 FFR response function results. Apparently I cannot gather the whole 48 cases in on single table, so I am currently exporting the tables one by one. Is there any way to export a set of tables all at once (in one or several *.xls/ *.csv files)?
API ? Excel?
Thank you!
Solved by Rafal.Gaweda. Go to Solution.
Thanks a lot .. works perfectly !
One sapre question : is there any document that lists which columns number is related to which result ?
Set RT = RobApp.Project.ViewMngr.CreateTable(I_TT_NODE_DISPLACEMENTS, I_TDT_DEFAULT)
RT.Select I_ST_NODE, Nselection
RT.Select I_ST_CASE, Str(FRFCasenumber)
RT.AddColumn (1783)
RT.AddColumn (1784)
RT.AddColumn (1785)
this is where you get the speed result ? Ihave found the number for acceleration but do you the list for all numbers?
Path = TempFolder + "\" + "FRF case " + Str(FRFCasenumber) + " results.txt"
RT.Printable.SaveToFile Path, I_OFF_TEXT
Open Path For Input As #hFile
OpenTextFileToString = Input$(LOF(hFile), hFile)
Close #hFile
AdjustString OpenTextFileToString, k"
No, get columns numbers first from opened table by you in robot
Then use them in RT.AddColumn
Yes We manage to do that and also to export in .csv file !
I think I'll try to make something more general to edit any data I want in .csv file, but still don't understand How do you that to get acceleration for exemple, you have to addcolumn 1789 or XXXX ? We is that piece of information?
Thx and good we.
TS
Chenges in the code made
RT.AddColumn (1789) RT.AddColumn (1790) RT.AddColumn (1791) RT.AddColumn (1792) RT.AddColumn (1793) RT.AddColumn (1794)
For j = 1 To 9 ' 9 here
