Has someone already implemened a spreasheet or a little API to define and update easely the bar types in big models?
If not, I think I will try to code that.
Thx
Solved by Rafal.Gaweda. Go to Solution.
Example for steel bar
Dim LabelCol As RobotLabelCollection Set LabelCol = RobApp.Project.Structure.Labels.GetMany(I_LT_MEMBER_TYPE) Dim RLabel As IRobotLabel Dim RdimLabelData As IRDimMembDefData Dim i As Integer i = 1 While Cells(9 + i, 1) <> "" Set RLabel = LabelCol.Get(i) Set RdimLabelData = RLabel.Data RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Y, CDbl(Cells(9 + i, 2)) RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Z, CDbl(Cells(9 + i, 3)) RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_X, CDbl(Cells(9 + i, 4)) RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_Y, CDbl(Cells(9 + i, 5)) RobApp.Project.Structure.Labels.Store RLabel i = i + 1 Set RLabel = Nothing Wend
