I have to model 3 EOT cranes that move simultaneously on a 5 bay continous beam.
Everything seems ok except combining all three to get the maximum efforts.
When I define a combination using 2 movig load cases, Robot generates the combination correctly.
But when I define a combination using all 3 moving load cases, a combination is generated, but no results are given.
How can I get the maximum efforts for all 3 moving at the same time?
Thank you
Solved by Rafal.Gaweda. Go to Solution.
Hello Rafal,
Please find attached the file.
Where can I read more about moving loads, and how Robot handles them?
Thank you
You want to generate ~389017 (73^3) combinations but your limit is set to 64000.
Change it.
