Just loaded the 2014 professional version and the help link goes to a site http://docs.autodesk.com/errors/404.htm. "page you were looking for was not found" Since this seems to be all internal how do I fix accessing the help?
Solved by LieberSteve4929. Go to Solution.
Are you able to access this location?
http://docs.autodesk.com/RSAPRO/2014/ENU/index.html
Not unless I type into the browser to change the web page. The F1 key takes me to the link shown, I do not know what page it was trying to find.
Same error on this link:
in place of ARSA help is opened error page:
Other than English help worked on my computer:
http://docs.autodesk.com/RSAPRO/2014/PLK/index.html - worked (Polish help)
http://docs.autodesk.com/RSAPRO/2014/RUS/index.html - worked (Russian help)
http://docs.autodesk.com/RSAPRO/2014/DEU/index.html - worked (German help)
http://docs.autodesk.com/RSAPRO/2014/ITA/index.html - worked (French help)
http://docs.autodesk.com/RSAPRO/2014/FRA/index.html - worked (Italian help)
English help for ARSA Pro 2014 - not worked:
http://docs.autodesk.com/RSAPRO/2014/ENU/index.html - error page (English help)
Problem is under investigation.
I hope the site will be corrected soon.
Did not have to follow directions of press F5 or use different browser, Help link started working on Friday 4/26. Thanks for resolving this issue.
