2014 Robot help link broken
13 REPLIES 13
Message 1 of 14
LieberSteve4929
1033 Views, 13 Replies
Just loaded the 2014 professional version and the help link goes to a site  http://docs.autodesk.com/errors/404.htm.   "page you were looking for was not found"  Since this seems to be all internal how do I fix accessing the help?
13 REPLIES 13
Message 2 of 14
bump for help. Still getting not getting to the Robot help when using the F1 key or drop down menu. Since I do not have a manual depend on the on-line help. Oh what to do.
Message 3 of 14
Are you able to access this location?
http://docs.autodesk.com/RSAPRO/2014/ENU/index.html
Artur Kosakowski
Message 4 of 14
Not unless I type into the browser to change the web page.  The F1 key takes me to the link shown, I do not know what page it was trying to find.
Message 5 of 14
Actually the link you gave me gets me to same error page when I click on it.
Message 6 of 14
legar
in reply to: LieberSteve4929
Same error on this link:
in place of ARSA help is opened error page:
Message 7 of 14
legar
in reply to: legar
Other than English help worked on my computer:
http://docs.autodesk.com/RSAPRO/2014/PLK/index.html - worked (Polish help)
http://docs.autodesk.com/RSAPRO/2014/RUS/index.html - worked (Russian help)
http://docs.autodesk.com/RSAPRO/2014/DEU/index.html - worked (German help)
http://docs.autodesk.com/RSAPRO/2014/ITA/index.html - worked (French help)
http://docs.autodesk.com/RSAPRO/2014/FRA/index.html - worked (Italian help)
English help for ARSA Pro 2014 - not worked:
http://docs.autodesk.com/RSAPRO/2014/ENU/index.html - error page (English help)
Message 8 of 14
Rafal.Gaweda
in reply to: legar
Problem is under investigation.
I hope the site will be corrected soon.
Rafal Gaweda
Message 9 of 14
Rafal.Gaweda
in reply to: Rafal.Gaweda
Fixed.
Rafal Gaweda
Message 10 of 14
Link still does not work when I tried from drop down screen inside Robot. Fixed??
Message 11 of 14
Message 12 of 14
I clicked on the supplied link, copied and pasted below, and still get sent
to the error page.
click here: http://docs.autodesk.com/RSAPRO/2014/ENU/index.html and ?
Message 13 of 14
clear browser cache or press F5 on browser or use different browser....
Rafal Gaweda
Message 14 of 14
Did not have to follow directions of press F5 or use different browser, Help link started working on Friday 4/26.  Thanks for resolving this issue.
