Hello All
I am having a problem when aligning two wall faces.
I have two concrete walls that had a 54mm projection from each other, I now have to the outside faces aligned (flush) with each other. when I try to align the faces of the wall that I want to move, the other wall that I am trying to match to is also moving. essentially both walls are moving. this is the first time I have run into this problem and I was hoping someone could tell me why or how I can go around this.
Thanks in advance
Kevin
This is usually caused by locking the walls to something. Unless you can find the lock to un-lock it this can be a real head-ache. My work around is to copy the wall you want to move to the correct location and then delete the old one.
