the ramp command under the architect tools.
not familiar with the slab edited by grips or is this where
you specify the slab as being variable in the elements properties and then using the modify sub elements ie the z coordinates. this is ok for slabs with a flat soffit but as far as i'm aware you can't alter the slab soffit to falls in this way.
thanks,
pete
