Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
setting up my sheet for printing
1 REPLY 1
Akunkinga
369 Views, 1 Reply
image1/question 1
in a sheet view :
the square box denoted as shown just inside red dashed line,
around the imported link is big how do i make it smaller or does it not matter
image 2/question 2
in elevation view
i only want to show the area within the red dashed line when i put this on a sheet
also how do i hide the architects grid lines and level markers on my sheet view
qusetion 3
in my sheet view
how do i stop the elevation symbols that are on the plans from printing ie North South East West
1 REPLY 1
subhra_civil
in reply to: Akunkinga
First of all i want to inform you that you have to any changes in Plan, Elevation, Section in stead of Sheet.
1. In your Plan View just on Crop View & Crop Region. With this you will be able to opatate the plan size small & big as per requirement. Please see the attached image-01.
2. Same thing will be repeated in your query-2. Use Crop View & Crop Region. You will be able to all Grid line and Levels off thru "Off" them in Vigibility Graphics. Please see the attached image-02.
3. In plan view you have to off the "Level" in Vigibility Graphics". Please see the attached file image-03.
Note:- you have to use "on/off" option in vigibility graphics in Plan, Section & elevation where you exactly want to off or on.
Thanks & regards,
Subhradeep Sen
Kolkata
India
