Solved by kathryn.langan. Go to Solution.
When you open the ADSK file in Revit, go to the Family Category and Parameters dialog. If it's a Generic Model family you can check the box for "Can host rebar". You could also change the category to Structural Foundations and you should be able to host rebar.
I hope this helps!
