Hi all,
I linked another revit model to current model. The reference model has not shown all the annotation elements in current model.
The reference model has been added of the annotation before linked. How can solve it.
Solved by lzaras1. Go to Solution.
I'm not sure I completely follow your issue (may be a language translation error.)
You can reload your linked model. (Manage Tab > Manage Project Panel > Manage Links tool)
Once reloaded, in your Visibility Graphics, change your Revit Links, Display Settings to <By Linked View>.
Hope this helps. If not, please try describing your issue again.
