Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
"Beam-based" family
2 REPLIES 2
pnacht
584 Views, 2 Replies
"Beam-based" family
Is there a way to create such a family?
More to the point, I'm trying to create a prestressed cable family, which goes through a beam on one face and comes out the other. I've already created a certain form of this using a face-based family, but that has many limitations. It only works on straight beams (on a curved beam it would keep going straight), the user needs to input the length value of the cable, etc. It has occurred to me to create a "Prestressed Concrete" beam family which comes with the cable contained within it. This would solve the curved beam issue and the length of the cable will automatically be the length of the beam. This might be a useful implementation, but it also has its limitations. Many times a cable doesn't run the full extent of the beam, coming out somewhere in the middle of the span. In such cases, the cable needs a special anchoring region which usually protrudes out of the face of the beam. Such a case would not be possible with a simple beam family (well, not without creating dozens of different family types for each beam cross-section).
So, is it possible to create such a thing as a beam-based generic family?
2 REPLIES 2
pnacht
in reply to: pnacht
Sorry to ask again, but...
How does one come to create a XXX-based family? Is it even possible? Can I start from a straight-up generic family and add a base member as one of it's parameters, for example?
AJA14
in reply to: pnacht
Hi. This calls for nested families. I'm not sure how far you can go with that, but nested families enable you to place one family into another, and then this one into another and so on. However, you need to be well aware of how to create them and link them together using reporting parameters which may also be custom created shared parameters. Take a look at this issue and let us know if you have any particular question. Regards.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Rail Community
