It doesn't give a real answer with thousands of piles you cant insert and number all the piles
@Anonymous wrote:
we use a couple of different generic tags for similar purposes. For
example, you can use a custom tag that calls the data in the "Comment
Parameter". If you get that, then it is easy to understand how you can
make a tag to call any other bit of data, provided the parameter has
been added to the family. Open your pile, and add a parameter for Pile
Number. Make it an instance parameter, and you could make it either a
text or numeric field. Then you can (manually) add the number value to
the parameters when the pile is inserted in the model. The parameter can
also be scheduled if desired.
Hope this helps...
R
We have downloaded from the following website a Revit Extension.
Once set up you can give each pile a unique number to add into the pile schedule.
