Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
monolithic stair - how to match with the structural floor !
1 REPLY 1
ahmedgaser
1016 Views, 1 Reply
hi
i have a bad problem with a 3-flights monolithic stair , you can clearly see it in the image attached to this message !
simply i want the area inside the red mak to be like the other one in the green mark ! knowing that the red one between stair run and floor while the green one between the stair landing and the run !
note : this issue sometimes occurs and sometimes not ! i don't know if it is related to the structural floor thickness or what !
this is very confusing to me, i can fix this issue in 2d view by using " cut profile " tool ! but i want to fix it within the 3d model !
waiting for your advice
thanks
1 REPLY 1
in reply to: ahmedgaser
This is occuring for different thickness of "Waist Slab & Floor Slab". But Structurally there should be a Beam at the top floor where the stair is finally finished. I am sending you a file for your help. Please find the attached file.
If there is any queries then please send me reply. I think this file will help you for your query.
Thanks & regards,
Subhradeep Sen
Kolkata
India
