In plan views we show the perimeter of floors with a triple dash line which is set in the object syles. This also makes the perimeter of the floors in all other views and sections the same line pattern.
Is there a way to show the triple dash lines only in plan views and show solid lines in all other views without doing an override?
Solved by alan.quinn. Go to Solution.
You could create a filter in plan, then create a view template from that filter, then apply the view template to your floor plans where you need the floors to show up differently. See this link for a file the shows the above method https://dl.dropbox.com/u/11938886/AQ_07675013.rvt
Look at Levels 1 and 2, the floor edge is dashed because the view template (AQ_Filter) is applied. If you want to turn it off set the view template to none > right click on the floor > override graphics in view > by filter > click on the (Floor) filter and click remove. Its a little bit of work, but its gets you what you want and the floor is not effected in other views.
Hope this helps and thanks for posting.
