Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
how do you draw slab in revit?
2 REPLIES 2
huyxp
823 Views, 2 Replies
hi all
when i draw slab in revit i don't know draw slab for true?
boundary of slab is edge outside of beam or edge interior of beam??
2 REPLIES 2
AJA14
in reply to: huyxp
The edge should be outside of the beam. However, if you are planning to later work on transferring the model to Robot, then you have to do some work on the analytical model.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
in reply to: AJA14
Another point is the slab volume--check values of modeled outside vs inside the beam edges.
