Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
export/import guide grids
2 REPLIES 2
DParkRMAK
1074 Views, 2 Replies
Is it possible to export or import guide grids between projects? I thought it was but I can't seem to find any way to do it.
2 REPLIES 2
This is a good question. After some tests my conclusion is that you can't. But the best workflow for now is to save the last project as a Template then you will be able to find them in there.
We could consider your question as a wishlist. I encourage you to send a wishlist to Autodesk Development team via this site (link HERE) for your case.
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
in reply to: DParkRMAK
You can "import" the guide grid by opening both projects and going to Manage > Transfer Project Standards then checking the "Guide Grids" box
Tags (1)
