Having an issue with steel beam framing connecting to slanted columns analytical lines, they are not intersecting cleanly as the physical geometry is doing. is there a way for the analytical to clean this join and align appropriately?
noticed by adjusting the start y projection analytical alignment to centre of element will clean up slightly offset beam nodes, does not seem to function with the slanted column centre line.
Does adjusting the tolerances in the structural settings do anything? any guidance would be appreciated.
Appreciate the feedback conormccartney3897
