Hi!
When I zoom out, lines that must be hidden becomes visible. So, when I plot the drawings that lines are plotted too under the roof... but that is incorrect!
The following screenshot shows the same view with differents zoom's levels...
Can you help me?
Solved by kathryn.langan. Go to Solution.
The hidden lines are just a limitation of regenerating the graphics. Depending on the thickness of the lines and the zoom factor, the hidden lines can show through. This shouldn't affect your actual output though - if you check a Print Preview, it should display as expected:
