You can create a retaining wall. First, Duplicate one of the Basic Wall families, say the Generic - 8". Rename it to Retaining - 8" Concrete. Edit it's Structure to use 8" Cast in Place Concrete. Change its Wall Function parameter to Retaining.
Using that Basic Wall type, model a wall in whatever layout you want. Corners will miter.
Go to the Modelling tab in the Design Bar and select Foundation >> Wall. The default Revit Structure template comes with a Bearing footing and a Retaining footing loaded. If you Edit the Type parameters of the Wall Foundation family you will notice the Structurage Usage parameter can be either Bearing or Retaining. Bearing will yield only a Width whereas Retaining will yield Toe Length and Heel Length.
So, select the Retaining footing the select the wall(s) you want to have footings. You are able to flip the toe/heel by picking the footing and clicking the double arrows.
Brian
Edited by: johnsobr on Nov 8, 2008 6:28 AM
Brian E. Johnson, P.E.
AEC Technical Specialist
Autodesk, Inc.
